As the title says I cant get my passenger door to open from the inside or ou if anyone has anyone has advice I greatly appreciate it
how cold is it were you live it might be frozen, or is it locked
Stuck lock? Take off the inside door handle n pull the lock lever with your fingers.
It’s about 20 - and the door panels off when I pull the interior door handle the latch dont move but if you pull the outside it does move it looks like it just ain’t moving enough I’m gonna have to do some work on it tomorrow I guess when I’m done work. ( so many issues with my car at the moment urgggggg)
Ah ok. This happened to me on the drivers side. I fixed it by rebending the door handles anchor plate. After a lot of use these things can straighten out and not pull the lever as well as it used to. I’ll post a pic up in a sec.
Ok my computer is being stupid. Basically try to get the handle to sit a far forward as you can. The base plate has oval holes to do this.
Yea I kno what ur talking about I got the db1 rears handles on my front and I kno it prolly needs adjustment I just need to get the door open so I can f with it
