Reading through the the tips I came across a way to fix the leaky passenger side.
Howeve before committing to it I want to make sure it works.
So will replacing those seals/gaskets fix my problem?
i think that was discussed before already. someone from g2ic did that methond but I think after awhile it began to leak again.
I totally gave up on that and decided to improvise using the ghetto method. no leaks so far.
you can always do both methods, the Teg tips way and the ghetto way
http://www.g2ic.com/forums/showthread.php?t=176783&highlight=passenger+leak
and
http://www.g2ic.com/forums/showthread.php?t=138017&highlight=passenger+leak
