Did the teg tips way but still getting the leak.
Much more water coming in than before.
Anymore suggestions on where it’s coming from?
Thanks.
where exactly is it leaking from? Did you change all the plugs and clips and stuff under the cowl assembly (including the foam seals that go under a few of the clips?)? When I did my car, I just changed every clip that the cowl assembly had under there,
All I changed was the white rubbery parts that was in the teg tips.
Maybe I should have changed all of the clips & everything like you did.
But I wouldn’t have known till I actually did it.
I just followed the teg tips & it didn’t work for me.
I’ll probably have it fixed professionally.
Whenever I try to save money, it seems to be not worth the effort.
