passenger side window won't go up/down
yesterday both my windows went up and down fine. a little slow, but that is how they always are. later on that night, i went to roll down the passenger side window and it didn’t go down! i checked the fuses and none of them are blown. i think that the motor might have given me a little bit of warning before it went out. does anyone know if there are any fuses that i might also need to check or there is something i missed…
I ran into the same problem the other day. My Passenger window was working fine. Then all of a sudden the passenger side window will go down but not up. But when I control the window from the driver side, the passenger window goes up. Can u control yours from the driver side?
clean the contacts with CLR
yeah, pull the switches apart and clean the contacts. it helps quite a bit. if that doesn’t fix the problem, then its probably the motor
