Hello
Yesterday I replaced both of my doors due to rust, and was told that the passenger window was off track.
So I put the new ones on, and lowered the pass. window, it was off track indeed but it went down all the way. I then tried to raise it back up, and nothing happened. No noise, no motor trying anything, just silence. I tried multiple switches from 2 door panels, and I tried the master controls on the drivers side. I checked the fuses, they look fine. I also put the window back on track from what I could see, and that was to no avail. What happened and how can I fix it?
So I checked some contact points, and got the window to move again. Now, the window is way off track or something ,even though I thought I fixed it. It moves side to side, and clicks, makes terrible noises when going up and down.
Roll window down, detach from regulator, and by hand slide it up and down, if guides are in place, and as long as you push window up level it should slide easily up and down, if so the regulator is the problem, if not, [pops out of guides] the guides are a problem.
You will have to check the guides, make sure they are not bent and/or twisted, they are bolted into place properly, make sure rubber inserts are in place, pay close attention to the front guides lower mount, make sure a previous owner has not spaced it back with a spacer or washers for speaker magnet clearance.:hmm: 94
