ok, i have been working through the process of putting power door locks and power windows in my car. the car is a 91 ls that didn’t have power anything, but the body harness in it now is from a 93 ls that had power windows but not locks. so i got the door harnesses from an integra gs and power window and door lock actuators for both doors. so i wired up the door harnesses to the car and i new i would have wires left over from the harness to the door because the car isn’t set up for power door locks, and that is how it was on the drivers side. but on the passenger side there are extra wires on both sides and the window only goes down, not up. and when the car is on it beeps like the door is open and the passenger seatbelt doesn’t move. i looked at the plug that goes to the door lock actuator and it matches the unused wires so im assuming that is the problem but how do i tell where each wire goes? i also found some unused plugs down by the seat belt control unit. does anybody know where these go?
extra wires from door harness:
extra wires from body harness:
extra plug A:
extra plug B:
extra plug C:
plug C also had a rubber stopper thing in the end of it:
