Okay, I was trying to replace the PCV valve on my teg when I ran into a HUGE problem. As I was trying to pull out the old one, it broke in my hand. Half of it was stuck in the intake manifold while the other half in the upper hose itself.
When I tried to use a flathead screwdriver to pry up what was stuck in the manifold, I inadverdently broke the plastic “socket”
that the PCV valve itself plugs into.
Now I have white smoke puffing out of my exhaust & my check engine light is on.
How can I get to the rubber tube/hose under the manifold to connect the new PCV valve without having to remove the manifold itself? :bang:
