Im searching for a thread or post with front and side pics of a black DA that has wheel spacers and a wide aggressive stance… I think it might have said the wheel spacers were 20mm in front and 15mm in rear not sure but I wanted to confirm and look at the pics again.
that doesn’t look to bad. i guess if the wheels weren’t OEM it would stick out too far. i say to get the wider look out of an OEM, spacers are good. but anything at least 7" wide should be fine. you ever had problems using spacers? I’ve heard some people say they aren’t good for the car
No problems at all. I ran them for a few months and it felt great. This summer ill be running them with some aftermarket wheels and see how they sit then so well see what happens.
Wheels studs. No no problems with them. I bought mine off of rexone on here. Heres the link http://www.g2ic.com/forums/showthread.php?t=195843&page=2 you can see on page 3 how they go on in those pics. You dont have to extend your studs with these. I forgot wat brand they are. Maybe rexone might remember.
Nothing much rex. Im gettin rid of the Da tho. All the aftermarket parts that are on it are coming off and going on my Db1 tho. Im selling it as a shell all stock. Yea thats the brand now that i remember i kne it had tcs somewhere. Your Db looks nasty i hope mine looks like that good.
I would of thought the db1 would have a wider stand with 20mm spacers but it kinda looks oem maybe its the camber above that makes them look pushed in from the top of the wheel well.
I was running 205/50/15s with no problems. No rubbing issues or nothing. Heres their site im not sure what they run for new http://www.tcsportline.com/
do u know off hand what factory offset is on the teg some were around +38, +40
and if i dont want to run spacers (say a 20mm spacers) i’d take the factory offset minus the spacers width of 20mm and i’d get the correct offset i’d want. lets say on a 16x7 wheel
another good company that makes spacers is ichiba i have some 20mm spacers on the rear of my teg and the rims stick out very slightly past the fender.and they are the kind with studs attached to the spacers.
the offset on the te37s were a +42
you dont want to go a higher offset because the higher you go the more sunked in they will be
i think the perfect flushed offset without rolling fenders would be +30. i ran some rims that were +25 and they were flushed to my rear fender but that was with natural camber. also it didnt rub. here is a few pics of my
Work RS Betas
16x7
+25 offset
205/40/16 tires
here is the rear
