Please HELP. Engine losing power suddenly and randomly…
My car is a 93 Hatch LS with 58K original miles on engine/body. I keep up with oil changes. I got the car with 32K original miles. Ive replaced the starter and left and right driveaxles myself. I havent replaced fuel-injectors, or sparkplugs since Ive had it though.
I was warming my car up, for 10 minutes and the power suddenly went out without any signs. No check engine light either. I try to get a jump, no such luck. Car is rotating but not catching a spark or sparking. I even try push starting it since its a manual. No such luck.
I come back later that next day, and first attempt at starting the car, it almost catches but doesn’t. I try again and it catches. I rev the engine and hold at 1200-1400 RPM for about a minute. The exhast smells strong of gasoline, probably from me flooding the engine. The smell goes away in about a minute, and then I let it idle and everything is fine. I turn it off and then back on. It starts without a problem. I take the car for a 5 miles drive and back. Everything is fine. I come back to it a few hours later and it starts fine. I take it down the street, about 2 miles and the power is SUDDENLY cut from the engine. And it wont start either. I leave it there and come back that morning and it starts fine, but cuts out again while coming to a stop. I had to get the car towed back home. And now the car wont turn over at all. Whats wrong?
