Please Help Me Fix My Retarded Idle [videos inside] yes i've searched full story insi
k so my car is a 92 GS with a second generation B16A swapped into it, the garage that sold it to me did the swap not me. I bought it before winter hit and the idle never hunted at all then as soon as winter hit it started hunting all the time, and now winter is on its way out and its still hunting. I’ve tried everything to try and fix it. I’ve gone through this list http://www.g2ic.com/forums/showthread.php?t=42969&highlight=idle+step the best i could and its still hunting. i also did this http://www.g2ic.com/tegtips/engine/10.html last night and its still hunting. my ground cables are 4 gauge aswell by the way.
[b]VIDEOS:
http://youtube.com/watch?v=FswFPfwQWpk
k so that video is just the car idling at normal operating temperatures and me and a friend just tapping the gas and watching the idle hunt, so you can see how bad it hunts.
http://youtube.com/watch?v=FNq0edeXHRo
that video was me driving while filming my tach so you can see how bad it hunts while i’m driving, every time u see the RPMs drop down and i’m not shifting i just threw down the clutch pedal and i’m sitting there coasting without touching the gas or the brakes and u see it hunt. it seems to hunt about 200 rpm higher then while idling, also sometimes i have seen it jump up to 2100 but i unfourtunately didn’t catch that on film but it does do it quite often.
the sound is a bit off on both videos but you get the idea…[/b]
I have cleaned the FITV and IACV as best as i could, i had them both completely off the car and cleaned them with throttle body cleaner and tightened down the FITV white cap as tight as it could go and i also cleaned the area around and as far into the intake manifold as i could before putting them back on.
now going back to this list http://www.g2ic.com/forums/showthread.php?t=42969&highlight=idle+step
  1. I have checked my vacuum lines myself from atop the car and from underneath it the best i can using a diagram from mitchell on demand5 i didn’t find any bad hoses but then again i’m not a mechanic and i’m not a pro at it. my pcv valve is fine.
  2. yes my throttle plate is closed all the way…
  3. yeah i checked these nuts and they’re all good and tight
  4. haven’t bleed my coolant but if there is air in the lines and thats whats causing the hunt wouldn’t it stop after they’ve cycled through once? or would it continue and continue. i dont’ think this is it though because as i said my car didnt’ hunt before winter but ever since winter hit it has and i didn’t bleed the coolant or anything during that time the only thing i did was add to it once in awhile. could something have gotten screwed up here when i was working on the IACV and FITV and had the coolant lines on? i know i put them back on the right places but could air have gotten in?
  5. as stated before already did this…
  6. as stated before already did this…
  7. i did test this but i dont’ remember the results i’ll have to do it again and post back here…
  8. haven’t done this yet
  9. um definitely dont’ ahve the money to spend for a new ecu…
i have also had the car running and sprayed throttle body cleaner around the engine bay to see if the engine would rev therefore finding my vacuum leak but this revealed no results. and today i also tried this with compressed air, still no results…
so at this point i’m thinking about taking it into my mechanic and asking them to try to fix it and see what they come up with.
what do you guys thing i should do?
and if anyone can point me to where i can find a good vacuum diagram of a b16a in an integra without it costing me money then please do so.
and one more thing my car has an AEM fuel pressure regulator if that matters at all…
Similar Problem
:bigread:
This has been going on way to long…
I have a 91 ls with stock engine…
ive been having this problem ever since i replaced the engine this is approx the 4th engine the others i had bad head gaskets so i had to keep changing till we found a good one…
Well here i am a year later with the same idling problem ive gone threw ever idling forum i can find and have done 98.99% of all possibilities…
It idles very low and almost stalls when cold when its warm the idle hunts up and down and when i come to a stop the car almost stalls and in most cases does stall
I have had this problem with all stock parts…
So i replaced the IACV twice along with cleaning all of them… No Difference.
Replaced Map sensor with one from a friends teg… No difference
Changed Throttle body with a used TB & TPS Sensor along with cleaning and replacing the gasket… No Difference
Changed to a Blox intake manifold… No Difference
Replaced PCV valve and Hose from Acura… No Difference
Changed Every Vacuum Line i can find… No Difference
Replaced Cap N Rotor… No Difference
Replaced Batter Cables + & - No Difference
Replaced Plugs & Wires with Ngk… No Difference
Replaced O2 Sensor with a Denso…No Difference
Replaced Valve Cover Gasket and Spark Plug Grommets… No Difference
Replaced Fuel Filter… No Difference
Tried my friend ECU… No Difference
Checked Throttle Plate and its fine…
Ive bleed the Coolant and refilled still… No Difference
What are the Chances of it being the Ignitor?
Could i need a valve job?
:bang: :mad::wtf: :shrug:
Any other possibilities
Later on i will take some pics and vid of the situation if that will help
Akuma, you didn’t mention anything about your FITV, have you done anything with that?
I don’t have one with the blox intake manifold their is no place for it and before the intake manifold i cleaned it and tightened the white screw still same problem
Ah I see okay… hmmmm.
did you check the voltage of the tps ?
I Have not checked that… not sure how too ive also had the alternator checked and they said it was fine
I haven’t checked my TPS yet, I was going to try to tonight but my buddy forgot to bring the voltmeter lol I’ll test over the next couple of days and give the results.
Did you find what the problem was. I have the same low idle when it is cold, and the same hunting when it is hot. I have checked all of the same things you have. I have noticed that after I warm up the car and unplug the IACV connector it will go down and stay down. So I am pretty sure that the ECU is telling the IACV to open and close like that. But that also means that some sensor it telling the ECU that it needs to do that.
Thanks
