Ok, Im doing my timin belt right now and i’m in kind of a rush. I got the crank pulley bolt off and i need to know a few things.
How do you take the AC belt off?
How do you get to the lower power steering mounting bolt?
The lower alternator bolt won’t turn right…i turn it left and it has moved just a little bit like im tightening it…am i supposed to go right with this one or left?
How do i get the pulley off? pry it? the thing is stuck on there even though there is no bolt holding it
hmmm. think thats about it… thanks for any help
there is a long bolt that tightens down the third aac pulley…loosen that, its under the ps pump.
rachet(sp) an extension and a 12mm socket.
not sure right or left, but its always counter-clockwise to loosen for me.
what pulley, the crank pulley? it’s not gonna come off if you havent removed the other belts yet…I am assuming you still got all the belts on because of question #1 and 2 and 3.
If you are having this much problem with just the removing, I suggest you get help from someone or get a helms manual in the future.
