Has anyone ever had a problem with ur da stalling out only when you press the clutch in ?? I cant figure it out and nobody else can. Please help
Wrong forum, and your differential is probibly broken in the tranny. Lift the front tires of the Carr off the ground, put in neutral and see if you can spin the wheels by hand. If it is locked up, your tranny is the problem.
What forum should i post it in??.. but my wheels spin freely… it happens when i press and hold the clutch in ?
