Plugs for checking ECU code?
Okay I have a 92 Integra so I’m supposed to jump a plug.
I know i’m supposed to find some green plug. Thing is that I’ve checked everything (pulled the carpets back…the whole works) but still no green plug in sight.
Wire1
Wire2
Sorry for the blurryness…my camera doesn’t seem to take pics up close that well.
But IF these are the wires…then I am missing that green plug. Is that a bad thing? Do I really need it?
No one knows??
the second one looks like the plug that you jump when you adjust your timing. I don’t know what you’re talking about for checking codes. You just look at the blinking red light through the little ecu window. Ecu is located under the passenger carpet.
The 90-91 Integra’s are different from the 92-93 ones.
For mine, I have to read it from the check engine light.
Search Result.
