hey guys i searched in this forum thread and in teg tips and i cant find it. i remember seeing it on here somewhere, but does anyone know how to polish up the blades? because i know you have to use that stripper from kragen then i dont know which grit sandpaper to use. let me know guys thanks
start from lowest to highest (2000grit) either dry/wet and end with wet… then polish up with some kind of polisher… have fun…
and you can go here too same guideline
http://www.g2ic.com/forums/showthread.php?t=148138
depends on how bad the imperfections are on your wheel.
i started with some aircraft stripper. 3 / 4 of my wheels were in good condition. one of them had a few curb rashes on the face of the wheel so i used an orbital sander with 220 grit. after that you can work your way up.
best suggestion i could give you is spend your time with the lower grits and dont rush it… because if you jump to the higher grits too soon, you’ll be putting in a lot of elbow grease.
thing is the 3 / 4 wheels i had were already shiny once i removed the clear coat off of them with the aircraft stripper. so all i need is some higher grit sandpaper and use some polish to get a uniform shine and im good to go.
so it all depends on what you need.
