Porsche wheels
Hey All,
i’ve got a 91 GS 2Dr, and im trying to come up with some options for wheel setup. I have some BMW 14" E30 Basketweaves, 15x7 XXR 501s, Gunmetal with the Polished Lip, and 15x7 Borbet Hs which are on my Daily Civic. My Integra also has 14" GS Alloys. Down to the point, wondering if anyone had oppinions on other types of OEM wheels they like… I am really drawn to the Porsche Phone Dials and i found a few steal deals on them plus a junkyard down the road has a few for cheap money, however the pattern is 5x130 , i Can only find VW/BMW/AUDI 4x100 to 5x130 Adapters which are Cars with Lug Studs , Not Nuts like our Hondas… really trying to figure out if i have to remove my wheel studs to make these fit??? if so, Has anyone ever had to do such a thing or have any run ins with this??/ thanks!!!
Anyone???
if you really want to do it your going to have to drop almost 500 in adapters. but heres the site i got mine when i ran phone dials. I believe the specs are correct. i havnt run the setup since i crashed my coupe.
depending on which dials you get depends on the size of the spacer and the look you want.
i believe these are the most common sizes 16x7 et 52.3 and 16x8 et 52.3. so do some math and figure what thickness you need. that will in the end come in to play with figuring your effective offset.
the site http://www.motorsport-tech.com/
Type: Two Piece Adapter
Hub Centric to Car & Wheel Centric to Wheel
Number of Studs: 5
Thickness: 35mm
Stud Size: 12x1.25
Center Bore: 70.6mm
Diameter: 5 by 130 (5.12 inches)
Quantity: 4
