My 93 GS Integra seems to have an issue, it will randomly lock and unlock itself?? The door can be open or closed it doesn’t matter!! and the car can be on or off and it will do it. Has anyone else had this issue?? If so could you lead in the right direction of fixing this issue?? :hmm::hmm:
ummm…if the key isnt movin positions in the ignition…only thing i can think it may b is a short…loose wire…or may b one of the connections to one of the doors is pinched or coming loose…n each time it makes contact it locks the doors…idk…lol i tried
One of your door lock switches is bad, I had this same problem a couple of years ago. Once I switched the door lock on the driver side the problem went away.
