Possible dead injector help
Well I put in my 272 Delta cams, but they told me to put my fuel pressure at 44psi at idle, with the hose on the regulator. Now when I got my basemap from Xenocron for my b16 with mods, he said around 40psi at idle with the hose OFF is perfectly fine. So the 44psi with hose on that delta said when the hose is off is in the mid 50’s of pressure, so…
I know it’s just a basemap, and getting it tuned is the way to go, and I will, but what would be a more proper fuel pressure setting? I set it at 44psi at idle, hose on. Seemed to run just fine to, and wasn’t loading up as much.
Any help would be great, and yes, I searched, lol.
Injectors were sticking open from too much pressure, but now a different question posted above.
