Hi all. I have had DA’s and DB’s in the past and im looking for another. I purchased a mostly complete Greddy turbo kit that was for the DC2 96-99 LS and its one of the later model kits so it came with the actual Emanage piggy back, not just the blue box. My question is can I, and has anyone been able to use the Emanage that came with this kit on there DA. And if so how did it run, and how did you wire it??? I know the manifold, turbo, downpipe can work with some modification to the car and its components. And ill pick up the rest as I find what I need, but the Emanage has me stumped :stare:
I was able to dig really deep and found a diagram from Greddy showing the wiring for a Emanage Blue into a 94-95 integra, after seeing this I can only assume that it must be totally possible to use the DC2 kit on a 92-93 DA. But can anyone verify my assumption ???
It “should” work, if it works in an obd1 '94+ Integra.
Doubt that you’ll find a for sure answer on here though. Might have to just make an effort to make it work.
Why not sell the eManage for something that’s easier and neater to use? NepTune would be world’s easier and cheaper. No wiring needed, simply chip the stock obd1 ecu and call it good.
[QUOTE=unified112;2294271]It “should” work, if it works in an obd1 '94+ Integra.
Why not sell the eManage for something that’s easier and neater to use? NepTune would be world’s easier and cheaper. No wiring needed, simply chip the stock obd1 ecu and call it good.[/QUOTE]
I hear ya and I have thought about it. But on the other hand I have run this setup before on a 98 LS and I loved it. And its simple, once you wire it up and install the kit she’s good to roll. Never had any issues what so ever. But I missing having a DA and think it would be awesome to have a nice low boost turbo daily, while keeping the beauty of the DA alive :rockon: But yes if I ever get boost hungry I will most likely upgrade to neptune, or hondata
[QUOTE=unified112;2294299]Hah yeah I hear you on that one… I’m just used to what I run I suppose lol.
$175 got me a chipped ecu with NepTune and basemap… no wiring needed!
But as I said if it works on a '94+ LS, it will work on a '92-93… just verify wire color as they will definitely vary between generations.[/QUOTE]
Yea im gonna have to wire it up and roll with it lol. But I have to find me DA first!!! or DB Oh and I got my nearly complete Greddy kit for about $400 by piecing it together!!!
