Hey all, I just mangled my power antenna in the car wash(IDIOT!) any way i disconeected the motor so the gears dont strip but now my question is…can i get just the mast from acura or honda? any help much appreciated. Thanks
Re: Power antenna mast???
yup… you can get any of the pieces.
if you need the silver outer mast i have one. brand new never installed.
isnt it a bit hard to do that? i took apart mine for fun and it isnt one of the most practical things to fix unless you like tinkering with annoying things for a while. especially spending 50 on a replacement.
i just did the s2k antenna mod. about 20bucks in stuff, and you need a metric tap and die. check the tegtips
i dont drive through the car wash anymore either =P
Originally posted by XDEep
[B]isnt it a bit hard to do that? i took apart mine for fun and it isnt one of the most practical things to fix unless you like tinkering with annoying things for a while. especially spending 50 on a replacement.
i dont drive through the car wash anymore either =P [/B]
<img src=“http://students.washington.edu/locdaddy/s2k2.jpg”>
the mast is together with the drive gear, and if you buy it from honda or acura you will be paying for both. but if you can find a similar ordinary mast you can switch the drive gear and the top part of the mast to the new mast. juzt pull the ball like retainer at the top with a plier. and free the top most section of the mast.
