power door locks
ok i was installing new peakers in my doors today. when i took off the door panel i realized theres power door lock actuators on my car. what do i need to do to hook them up to my alarm. i have a viper 350hv. i have a couple pics of what i have on my car. on each actuator it has a green wire and a blue wire.
You will need two SPDT relays wired like this… http://www.the12volt.com/doorlocks/page3.asp#arp
Actuators/Reverse Polarity ^^^
Or you can get the DEI 451M, door lock relay pack that plugs into your 350HV, you will at least need the 350HVs door lock harness, it is a 3pin plug but probably only has a green and blue lead, no you can not connect them the the blue and green leads of the actuators, you need the relays. :whisper:94
[QUOTE=fcm;1960105]You will need two SPDT relays wired like this… http://www.the12volt.com/doorlocks/page3.asp#arp
Or you can get the DEI 451M, door lock relay pack that plugs into your 350HV, you will at least need the 350HVs door lock harness, it is a 3pin plug but probably only has a green and blue lead, no you can not connect them the the blue and green leads of the actuators, you need the relays. :whisper:94[/QUOTE]
So that’s TWO relays per actuator? And do I tie both “alarm lock output” wires onto the same “alarm lock output” wire? Same for the alarm unlock wire as well?
No, you will only need two relays, connect both actuators to the two relays, both the blue leads to one relay and both the green leads to the other relay.:corn:94
Gotcha! Thanks!
