power steering brackets
I just swappd a b17 gsr into my 90 integra and the ls upper bracket doesn’t line up…what power steering brackets can I use to get power steering back…
It has been mentioned in previous posts that you will either need the B17 brackets or shims to line up the LS brackets. I haven’t personally done this swap, but have done my homework on what is needed when swapping in a VTEC motor to a DA chassis.
ive been looking for the b17 brackets and cant find em anywhere do u have a link or something on where to buy the shims or how to shim it
You can use a P73 upper PS bracket and use a 1/4 inch shim between the bracket and the pump. The tension mechanism needs some modification to work, but I have done it and it works fine.
