Power steering pumps
Does anyone know if there is a difference in power steering pumps between 94-01 integra and 90-93 integra LS,RS,GS??? My 90 integra pump is all messed up at the mounting holes and I see a 94-01 pump for sale locally. I don’t know if they are the same or not.
Thanks,
Ryan
Www.acuraoemparts.com
Look up the part numbers for the pump for a '90 and a '94.
I believe they are not interchangeable… but I could be wrong.
It’s not listed for the 90 integra but it seems that there is a difference between the two. I might just repair the threads on my pump so it mounts up good.
why not grab one off a salavged vehicle?
worst case you get one with bad seals & that is a not so hard fix… plenty of writeups here about doing it.
That’s pretty much what I’m going to do. There is one listed at a local pull a part. Going to check it out tomorrow.
just to confirm, there is a difference between 94+ pumps as for the difference between the sub models, I believe all are the same except gs-r (p72) the mounts are different, which is slight variances in the pumps…
