I have a 92 integra rs that was converted to power windows by previous owner. I just barely noticed that my power windows can go up and down even with the car off. Even if the doors are open and the car off the window can roll down and up. I think this is draining my battery , because i didnt drive my teg for 4 days and it needed to be jump started today.
whoever wired them in tapped the power source to a constant 12v. check your fuse panel in the driver foot area. see whats tapped in there. just about the fuses there are slots where you can wire things in. see if there is something wired into 1 or 2
if there is, unplug it and see if your windows still work. if they do then you will need to pull the door panels and trace the wires to see where the power source is coming from. they may actually be wired directly to the battery.
Thanks for that pic. Theres actually alot of things plugged in down there. In all slots. The car has an alarm too, so one of those slots is for that. Ill start pulling some off see which one stops the windows from working.
Ok its slot 2. Edit** i got it now, moved it from slot 2 to 3 and now they only work with ignition on. Thanks man!!
glad you got it sorted out
