Hey guys both of my power windows were working normally till recently they just stopped working all of a sudden…I checked all the fuses and they are fine…I did replace the passenger side power window switch with a new one a while ago…so i know thas working fine. I donot know what else to do…is the main power window switch messed up that both windows arent working…any help would be appreciated…thanks
It could be th switch I had a problem with my passanger when that happened I un pluged it a plugged it back and a boom worked to check it I would get the volt tester and probe the wires at the motor and see if you get anything hope this helps
i know the passemnger side switch is fine…butt gotta check the drivers sidse is there a power window relay???
