hey i am taking the doors off a car with power windows and i need the windows to be rolled down in order to ship. is there a way i can hook up a battery or something just to get power to the windows so they can be rolled down? btw the car has no engine or battery, but all the wires are still there. what can i do??
Do you have a manual for your car? If so, in the wiring diagrams look for the diagram of the power window connector that connects the motor to the switch (inside the door panel).
Then, take your inner door panel off, and disconnect the power window switch. Have a 12V battery nearby and hook the ground terminal on the connector to the neg terminal on the battery, and using the wiring diagram, figure out which hole to connect the pos terminal of the battery to.
Should work anyways… maybe there’s an easier way…
