i want to know, I have a integra 92,can i use pr3 with the rods on my car without having any problems or i have to make any modificatoins to the block, or can i use it with my rods without shaving the rods.
Other question, if i put later the VTEC head, would i have any problem.
Originally posted by jaintegra Ok, But do i have to shave the rods, like when using the itr pistons, or can i use it stock.
no, you will not have to shave them. b16a and b17a pistons will not need the rods shaved. only b18c (any) and b16b pistons will require that you shave the rods.
you will need to have the wrist pins pressed out, which can break the piston in the process now n then. so i came up with a way to do it with out a press ;). takes about 5 minutes for each pin.
Originally posted by Speeddaddy you will need to have the wrist pins pressed out, which can break the piston in the process now n then. so i came up with a way to do it with out a press ;). takes about 5 minutes for each pin.
K Andee… cough it up homie… u letting yer frustatration out with a hammer?
