Pressing ES bushings into LCA
I recently bought a pair of stock rear lower control arms and the ES bushings for them. Yesterday I burned out the stock bushings in the control arms with a torch. I made it to this point and I can’t tell if the entire bushing is gone out of each hole. I basically just need to know if this little lip of metal is a part of the control arm or if its a part of the bushing that needs to be removed. Anyone who’s done this before and can shed some light on this for me? Thanks
That’s part of the bushing and needs to come out too. Would have been easier to press these out if you hadn’t removed the inner material.
-nino
Thanks man. Do you think I’ll be able to get it out without a hydraulic press? I was trying to get them out with c-clamp and a metal washer the size the ES directions said, but I can’t get them out. Thats why I thought it may be part of the control arm. I appreciate the help. :slight_smile:
Anyone think this arbor press would work? Its quite a bit cheaper than the hydraulic presses from harbor freight.
http://cgi.ebay.com/Arbor-Press-1-2-Ton-Presses-Ratchet-Lever-Heavy-Duty_W0QQitemZ390116221278QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad4bd215e
Use a hand held reciprocating saw and cut through the ring (make sure the blade is for metal and not wood)… one cut on each side opposite of each other to weaken the ring. Make sure you don’t cut into the LCA itself. Then use a flathead screwdriver or better, a punch, and knock it out with a hammer…
This process is very very easy if you have the reciprocating saw…
As for pressing in the ES bushings… you can do it all by hand with the use of grease they provide… no need for a clamp or vise.
Thanks hybrid, I was thinking about trying that but wasn’t sure if I was going to be overcomplicating things for myself. I figured, why cut it if I could press it out easily. Thanks for the advice!
