Has anyone ever tried to modify an OEM Toyota Prius rear lip to fit on a DA?
As long as the lip have almost the same curvature as the DA ones and the lengths are equal or longer, then it could be modded to fit the DA.
i’ve done that to my db1 when i first got it…it looked ok but was way too aggressive imo and the lip wasnt long enough(2 door bumpers are shorter so it might fit). wish i would of taken some pictures. modding it to fit was super easy because the material that the lip was made of was super flexible and had mounting holes all around. must of took me only 45 minutes to install.
sweet. i’ll try to get one for my DA. did you get it from a junkyard?
naw…i use to work at Toyota, and every now and then, you find an extra set.
Somebody can share up the pic?
THANKS…
