okay, my front side is starting to squeeq!! I didn’t have this silicon grease so I used normal grease! it seems that the grease is clearing out from the bushing and the metal surface… any ideas? shall I cut some grooves from the center of the bushing towards the outside so it retains some grease in it or it will make things worse?? any ideas?
oh well, no one has ideas to stop the squeeking of any bushing??
some slight grooves might help a bit, but I’d first try putting on some thicker grease, just get the thickest stuff you can find. You may just end up having to reapply grease more often. Good luck
well, thought so, although the idea of working this suspension again is not very appealing especially in the summer heat Anyhow, I may have overtourqued them, so I will check again and re-grease them once more.,…
