pro series skunk 2 intake manifold idle problems
i have just installed this intake, the stock intake had the FIT valve installed on it and the new one does not,i believe i have bypassed it correctly and believe i have all vacuum lines in there correct locations but yet i cant get the rpms to come down idles at 2100 rpms it is a 1993 ls 1.8l with a cold air intake and a greedy full exhaust with stock throtle body would have changed that to but ran low on cash lol…any suggestions would be helpful thank you.
When i bought my DB2 it came with a S2Pro IM installed and it does not have the FITV either. Also noticed that the IACV was re-routed some-what and its only utilizing one of the hose ports on the TB. I do not have any idle issues. I want to install my S2Pro TB but i have to research rerouting again because there are no hose fitting on the S2 TB. When i go to install my TB ill take some more detailed shots on how my mani stuff is routed. Maybe start at your IACV and work your way to the TPS settings and double check vac lines.
R1
did you try the idle screw on the tb? or adjusting the throttle cable?
Idling at 2000+ rpms means a major air leak! adjusting the idle screw will do nothing for you… I would go back and ensure that all your IM bolts are tight and that your cooling system is bleed of any air… An air bubble in the IACV will cause high idle like that as well. I didnt see you mention whether or not you changed the gasket?? A new/reusable gasket is almost mandatory when swapping IM’s
I had a similar problem when I installed my SK2 mani. after making sure my bolts were tight and giving the motor a good shake down. I got my Idle right back down to were it should be…
GL
R1 thanks for the help 1 more ? in the pic with the close up of the intake the large vacumm line on the top of intake looks like it routed down under the TB where is it connected under there this may be my issue again thanks for the help
BLKACK1 i did replace the gasket and when i noticed it racing i spayed the whole IM and vacumm lines with starter fluid to check for leaks and yet there was no change again all thanks for your help and input
