Problem after bleeding brake lines.
So i recently got my DB1 up and running after a while :excite: , i took it for a test drive around the block to see how she held up. but i noticed immediately that my brakes were extremely soft, to a point where i had to almost push the pedal to the floor. i went home and bled the brakes, went for another drive, and the pedal held up for a while at normal then started getting soft again? any ideas? :think:
Sounds like you are getting air in the lines from somewhere. My guess is the Master Cylinder, but check all of you lines and bleeder before you just replace it. Make sure they are sealing and have the correct copper washers on the banjo bolt at the calipers. Look for wetness!
