Problem/Solution: Excessive Smoke From Tailpipe
If you see a whole in the ozone layer above you, and notice FAT clouds of smoke just spewing out of your tailpipe everytime you accellerate, and a loss in power after 2k rpm, then it’s most likely something to do with your motor oil.
If you see this happening, check the motor oil level. It will probably be up half the stick or more. If this is the case, what you’ve got is not some magical car that creates motor oil, but instead you have gas in your motor oil.
How the hell did gas get in there?
Well the easiest way would be for gas to be pushed past the piston rings into the motor oil… this can be caused by many things.
Malfunction of your fuel injecters, injecting too much oil, thus making your car run WAAY too rich.
Spark plugs not firing! You may have very little spark or no spark at all, causing a whole bunch of gas to just get squeezed around into the motor oil. This happens when you try to accelerate really hard while you have no spark. (happened to me).
Solution:
Drain all your oil out (after car is off) and replace it with new motor oil. Run it for 2 or 3 miles (it’ll still smoke for awhile), then it should stop. If it continues, then you have a major problem with your piston rings or something. goto a shop and have things checked out by a pro =oP
hopefully nobody will run into this problem. this usually happens if osmeone’s alternator goes dead and a battery dies in the middle of driving, and the driver hits the gas a lot trying to see what the hell is going on.
