problem starting..main relay/ignition?
alright guys my car has problem starting up…its not my starter because i just replced that…when i turn my key to start it wont start i have to keep playing with it from on to turn on…
sometimes it starts sometime it doesnt…only way for me to start it sometime is the split wire trick n the neg and positve on the starter…
what do u guys think it is the main relay? or ignition
I believe is the main relay
So your saying the starter motor is not working and that is what you mean bu “not starting”, is that correct?
Also are you doing a bypass jump, “split wire trick” ? 94
