Problem w/ driver window switch help!
sup fellas im having a problem w/ my driver window it doesnt seem to want to go up i have to wiggle the p/w switch back and forth till it hits the right spot takes me about a min to get it to work.antbody know if the switch is going bad or maybe it the connector plug??? its really annoying!!!also i keep hearing a whining noise coming from the passenger side close to the firewall its like eeeeeeeeee then stops and awile later does it again???
you should post in electronics department. FCM is the man. he should and would be able to answer your question.
oh ok i think its just a bad switch
The switches get build up on them over the years. You can take them apart and scrape the black off the contacts.
