Problem W/ pedals
I jus bought APC indiglo pedals and i have the pedals actually put on my car but i dont kno wat wire to use for power so they turn on w/ headlights. Does ne1 kno wat wire to use? thanx
you can just stick it in one of the fuses in the fuse box by your feet. choose something that turns on when you want them to and the pedals will too
Or could could even splice the 12V IGNITION wire from your radio and run it there, that way the pedals will turn on when you turn on your car…
Unless they come with a switch… then you can just use any 12V power (radio, accesory, battery, etc.)
Ight thanx ill prolly hook it to my fuses thanx again
