My driver side window controls are messed up, my control to roll down da driver side window works but my pass. side control don’t work. (This is on the driver side controls.) Peace.
Try to slowly move the switch up and down (like move it a little further, and a little more etc) until it moves. If it moves after you hold it a certain way, your contacts are bad.
Check the teg tips on how to clean the window switch contact points.
If that doesn’t work…punch it. After that take off the door panel, you’ll then see the connection for the window. There’s this gue they sell at any and all hardware/electronic stores that will remove any rust or oxidation from the connections. Solder them back and it should be good to go!
Thanks. I’ll try dat. Already tried da first idea, no success. I check those connections, cuz its real annoying to roll down the pass. side by leaning across my console. Peace.
Got the same problem, I think everybody in this forum had the same prob.
