problem with hood latch
i was replacing my hood latch and for some now it wont catch the second latches at all…
there must be something ive done incorectly when taking the cable out and putting it in the new one…
has anyone done this before or know what i need to do to fix this?
thanks
you need to unscrew the two bolts that holds the thing to the frame, if its off by only a little it wont catch, you gotta move it to a certain point until it catches.
im pretty sure i have it lined up from top to bottom…
it seems as though it is lined up incorrectly from side to side…
are there markings for side to side as there are top to bottom?
i dont think thers any markings at all. if its side to side, the best thing to do is try to find your old marks left from how it use to be and try putting it there and see if it catches. usually, its up and down, too high or too low.
loosen the bolts hand tight and shut the hood…open the hood again and tighten the bolts up…that should werk too…
