Problem with JDM one pieces. Please help.
So installed my JDM one pieces yesterday and I didn’t use any harnesses. Just did a direct wire in using buck connectors and solder. I swapped the two corner lights sockets out and wired the one up that acts as a parking light and blinker. I originally had a problem where the passenger corner light blinker wasn’t working. Then last night, it started working again. But now if I go to put my right turn signal on, the left corner light blinker will blink with it and vice versa if I put my left turn signal on. Here’s a video of what it’s doing:
//youtu.be/rZVR-Micx9A
just leave them as a parking light
But then the bumper blinkers blink really fast.
for the sockets you dont use for the corner lights, did you take out the bulbs? that could be the cause of the blinking to be fast. why both of the corner lights blink when you use your directionals, idk. i’d say something happened to your wiring.
the corner lights are just parking lights. they arent supposed to blink. my car is an xsi and only my sidemarkers and bumper lights blink. those are just parking lights. if anything, take out the bulb completely…
one solution, since you have the fog light mod already, wire the corner lights in with the for lights directly and have them run off the same power source. completely remove the corner lights from whatever they are wired into and run them so they share power with the fogs. that way, you dont have to worry about them flashing or anything, they will just be on when the fogs are on…
this doesnt exactly “fix” your gremlin but it will for sure solve the problem…
[QUOTE=DA_all_day;2299236]the corner lights are just parking lights. they arent supposed to blink. my car is an xsi and only my sidemarkers and bumper lights blink. those are just parking lights. if anything, take out the bulb completely…
this doesnt exactly “fix” your gremlin but it will for sure solve the problem…[/QUOTE]
On USDM DA’s the 3 piece head lights have 2 bulbs inside the corner lights, a parking light and a blinker/parking light. When you install JDM one pieces on a USDM DA, you have to ditch one of the 2 lights completely. I chose to cut off the socket that was just a parking light and keep the blinker/parking light. But your idea with the fog lights is good. I’ll probably try that because I’m at a loss with this wiring. Nothing is shorting out and all my wires go to the proper wires and are all insulated.
I fixed the corner lights. Now they’re wired so they don’t blink at all and just the bumpers blink.
You did what I suggested or something else?
I just wired the corner lights back to stock. Now they don’t blink anymore and just the bumper lights blink.
