problem with my power window switch
ok, my master switch (on driver side door) works fine on all the windows, but on the right, rear window will only go down with the master switch but wont go up. To put it back up i have to use the switch on the actual door. Could anyone help me try to figure out why this happens and how i can fix it.
i have a 3dr hatch and switched master
my passenger wouldnt go up at all but i could make it go down and i just got a new master switch and it was like new it was pricey though around 149 for mine so yeah hope that helps
Pull switch apart and check connections had simliar problem in my buddy’s jeep simply the connection to lower it was touching howevere the connection to raise it somehow got pushed down simply bent it up and it worked
and i’d clean it and use dielectric grease to keep it from corroding/getting grime.
