The problem started not too long ago when I would put my right turn signal on with my head lights on at the same time, my interior lights and tail lights would go out and it didn’t always happen. Now it is to the point where every time I put my right signal on and only my right both the interior and tail lights go out. I’m not sure if it is a relay or what. :think: Another problem I am having that I don’t think it has anything to do with the turn signals is every once in a while my engine won’t start, it turns fine and usually when this happens the first time I try it kind of starts but then dies then it just turns and doesn’t start after that, then when I let it sit for an hour or two it will start right up with no prob.
turn signals, wipers etc most likely culprit: ICU
Startup problem: main fuel relay
I’ll look into that.
Grounds, Check your Grounds
