Problems with car..
Have a 91 GS with 207,000KM on it. Just found out what the weird clicking come from the motor bay was, looks likes the abs motor is failing or something, I also heard a hissing noise of air leaking from that area after the car was turned off, how much money would somehting like this cost. Also, apparently I have a coil spring broken and leaking axle seal, how serious are these things?
Thanks
JAY
i can tell u this right now. ur car needs a major tune up. would go2 a mechanic and find out how much it would cost or u can just buy a b16a. its most likely that time 2 do some redoing on ur car i would imagine i mean 209,000 miles that is a hell of a lot
He said 207K km’s!!:stuck_out_tongue: Which isn’t really that many miles. The only real problem might be the ALB (anti-lock brakes) unit. I don’t have a GS so I don’t know much about it. The hissing noise is probably just a vacuum leak since the intake is right there. Have someone else start and shut the car off while you check around to pinpoint it. The broken spring is a perfect chance to upgrade to some aftermarket lowering springs. Those can be had for around $130 USD new. Expect to pay about half of that for a single new factory spring. And new axles usually run about $70 USD per side.
