How do I adjust the front kit? I put it on, and the camber is still pretty bad.
With the progress kit, there really isnt much you can do in terms of adjusting. Pretting much a install it and forget it type of deal. There are two positions on the anchor where you put the threaded rod in. One is for +1.5 and the other is 1.75 i think, cant really remember since i installed the kit so long ago. Anywho, how low are you ?
like 3"s… what if i put washers in it to shim it. u know in between the kit and the frame.
Shimming wont do anything to change the camber. The kit is used for up to a 2" drop. At 3" i wouldnt doubt that you still have -1.5 to -2.0 degrees. Options would be to keep it that low and forget about it, Raise the car, or sell the kit and get the ingalls extreme kit or SP kit. Hth
