I pulled out an old alarm that was in my car but broken, and now my cluster lights dont come on, my headlight warning beeper doesnt come on when i open my door, and my tailights dont work. I am not sure wht to check. Something obviously came unplugged. thanks!
Have you checked the fuse? Fuse 11 - 15A, [hot when light switch is on] in under dash fuse box.
Also check the connectors/plugs around and into fuse box. 94
Update: after i posted this, i went out and pulled that fuse. it was fine, but the alarm drew power from that socket as well as a few others. It had those copper hooks on the ends of the fuses and it expanded the sockets so the fuses fit loosely. I pulled out the fuse and twisted the nds a little bit and pushed them in hard so they would fit tight. Everything is great! thanks for the help!
OIC fuse taps.:sad:
Sounds like you have it working again, when I run into those I will remove them and then just “tin” up the fuse “legs”, [put a thin layer of solder on both sides of leg that had fuse tap].:idea:94
