I was just curious when you pull out the motor do you have to remove any a/c components? or should the motor be clear of all that?
thanks to anyone who can help me out.
When I pulled the motor I just pulled the radiator first. Then I disconnected the AC compressor from the block and set it on the chassis where the radiator was. I had to tie down the AC hoses in the front of the bay to let the motor clear, but it worked fine…
Oh yeah… i pulled my motor from the top.
You don’t have to but like in my case where I was doing my motor at my dealership, it makes it a lot easier if you pull the compressor off and pull out the A/C line that goes from the firewall across the tranny mount to the front.
thanks for the advice. :bowthank:
