ok here is a quick how-to on custom push button starts
I use a relay that way I dont heat up what ever I use as the Button IE. a/c button, horn button, cruise control button etc etc
The relay I use is a 12v50A relay the not sure the number of it but it has 5 connections on it 30, 85, 86, 87, and 87a
ok well I am just going to do a basic one and not go into real details on how I did mine that way you can use any button
follow the ignition switch wires to the fuse panel below the dash.disconnect the black/white wire coming from the other side of the plug(coming from the starter not the switch side).
Find a place that has a switch power source on the fuse panel I think there is two or three.
now depending on if your switch is going to be supplying a - or + output depends on how you hook up the relay I will try and explain both
ok the wire you pulled off the plug that goes to the starter(black/white) is going to go to Connection 87 on the relay(if you depinned the black/white wire just heat shrink it and plug it in otherwise you’ll need a female terminal to connect it)
ok now the switched source you found in the fuse panel is going to go to connection 30 on the relay I would use wire that is alteast as thick as the black/white wire. I usually use 8gauge amp wire. ok now if your switch puts out a neg instead of positive your going to wanna hook up a wire from the connection 85 to 30 too this can be a regular wire but if your button is supplying a + source then dont do that.
ok now if your button is supplying a + source your going to run the wire from the button to 85
ok now if your button is a grounded supply your going to run it to 86
ok now to siplify it alil this is how it should be if your button puts out neg
when pressed
30-Switched power supply from fuse panel use atleast 8gauge wire
85-should be connected to 30(switched + power)
86-should be ran to your button(in my case was the horn button)
87-should be the wire that goes to the starter(black/white)
87a
there it should be done I would hide your relay that way its more anti theft and it makes the thief think
ok now how it should be if your button is supplying a + output when pressed
30-same as above
85-goes to your switch
86-run a wire to ground for this
87-same as above
87a-
you can also make it so your seatbelt has to be on etc etc
