I just installed a Skunk2 radiator and now I want to put a push pull fan but I want to wire it to my factory plugs! Now when I disco texted the wiring from the fan there was a green one which was wired to the fan and another white plug do I need the white one? Any help would be great!
Could you rephrase the question? I have aftermarket fans and I had to cut the wiring to the plugs and just reattached them using bullet plugs. It was easy enough, just make sure the fans PULL if you have them mounted between the radiator and the header.
As far as the plugs go, one is for the radiator fan and the other is the AC fan. I’m thinking the green one is for the Radiator and the white for the AC but i’m not 100% sure without looking at my car.
