these directions suck…they arent just like any other shock install…anyway, which way should my perch go so i can have 2" drop in front??? i put the perch setting to the middle one, but i dont know if the perch itself should be up or down???
do the bumpstops need to be cut in half???
i put the perch in downwards and the spring doesnt reach the top hat…is this how it sould be??? if i put in the perch upwards, the spring moves around all over the place and slides off the perch…whats up???
Usually, koni yellow users have the front perch on the very bottom and the rears on the very top to have that “even” look.
You can cut bumpstops no smaller than the yellow one on the pic.
Am not sure how the perch should be (it’s more likely to be upwards) but since the lowering springs are shorter, it wouldn’t reach the top hat like the stock one did.
I had konis but never paired it with lowering springs.
Originally posted by chipper
[B]these directions suck…they arent just like any other shock install…anyway, which way should my perch go so i can have 2" drop in front??? i put the perch setting to the middle one, but i dont know if the perch itself should be up or down???
i put the perch in downwards and the spring doesnt reach the top hat…is this how it sould be??? if i put in the perch upwards, the spring moves around all over the place and slides off the perch…whats up??? [/B]
ok, for the front, the perch faces DOWNWARDS…so it is like /–.
and yes, cut the bump stops in half…the middle perch is the same setting as ur stock shocks.
i got done installing them…there is a little less than 3 fingers of wheel gap and the spring does not shift at all…this has to be the right way to install it…and i didnt cut the bumpstops either…ill see how it works…worse comes to worse ill have to take them out…which is a whole 15 minutes of work
[B]i got done installing them…there is a little less than 3 fingers of wheel gap and the spring does not shift at all…this has to be the right way to install it…and i didnt cut the bumpstops either…ill see how it works…worse comes to worse ill have to take them out…which is a whole 15 minutes of work
how do you like the exedy organic racing clutch? I just bought one and I am putting it into my new tranny and pairing it with a clutchmasters 8.5lb flywheel
