Q about dome light
dome light does not come on when you open the door, light bulb is still fine just that light doesnt come on…any help/ideas how i can fix it!?!
fuse maybe
You have trip switches in your doors so when they open, the switch releases, and the light comes on… They’re black and slide back and forth - check if they’re broken. Both of mine are :frowning: :danger:
I used WD-40, buy it anywere(auto section of any store) or you could just some Personal Lube if you have some?:slight_smile:
:lol::lol::lol::lol::lol:
i just did this the other nite and used WD40 and it worked like a charm!
Do other things not work, such as the warning chimes and door ajar light? This was my problem, I took out the door switch and a ton of rust was on it. I used PB Blaster (like wd40) and scraped off as much as I could and everything started working after that…try it. There is a Teg Tip.
thanks guys…i’ll give it a try and let you guys know if it works
We have those? :S lol.
Perhaps I have the same problem :stuck_out_tongue:
Yeah man just go look at it, it only takes a few minutes…depending on how much crap is on your sensor. This was about as good as I could get mine…it was caked on really bad. I had no chimes, no door ajar light and the dome light didn’t turn on when the door opened. Now, I have them all back BUT for some reason the key-in chime beeps whenever I open the door, regardless of whether the key is really in or not. :shrug:
pb blaster and some sandpaper worked for me
