system
August 10, 2002, 6:53pm
1
i saw a website awhile ago that had some visual instructions on installing pistons, and i can’t think i where i saw it now…
so my question is, does anyone know of any good tutorials or can tell me what all is involved in installing pistons into your block
Colin
August 10, 2002, 7:51pm
2
system
August 11, 2002, 5:28am
3
i actually found the article on c-speedracing, but i’m wondering if anyone can give me any info that the weekend mechanic could use in addition
thanks for the site tho
the phrase “carefully tap” the pistons in.
means dont not hit them in with an oversized steel hammer from home depot… =) .
<img src= “http://central.mixture.com/Speeddaddy/images/B16_srp_piston.jpg ”> although it will work fine its jus not cool hahahha
:bored:
system
August 11, 2002, 7:10am
5
Originally posted by Speeddaddy
[B]the phrase “carefully tap” the pistons in.
:bored: [/B]
OUCH! :argh:
G2guru
August 11, 2002, 6:10pm
6
Use the wood or rubber handle of a hammer to drive them in. Make sure you have the piston and rings in the right orientation as well as having the rings FULLY compressed. Be sure to lubricate the cylinder with a liberal amount of oil as well as the piston skirts and rings before you put them in the ring compressor. It’s pretty easy stuff really.
system
August 12, 2002, 3:23pm
7
all right, thanks guys…
i plan on doing all this stuff in my garage, so would it be possible/easy for me to blueprint my block? and if i don’t, will my block suffer greatly?
