Kind of new to the board but here goes.
Will front and rear seats off a 94+ integra fit into a da?
What other options do I have for the rear seats?
will an ef or eg rear seats fit without much trouble?
If so is it direct bolt on or some minor fabrication?
I’m mainly looking for a cheap replacement
thanks.
[QUOTE=tommi3;2166266]Kind of new to the board but here goes.
thanks.[/QUOTE]
Just about any Honda seat will fit in our cars, it’s just not a direct bolt up. Your gonna have to change the rails to DA rails. I tried putting EP3 (01-05 Civic Si) Seats in my old DA. They came with EG coupe rails. I thought I had read somewhere that they were a direct bolt in, but I couldn’t get them lined up. Another thing you should look at is seat belts. We have auto seat belts and technically you are supposed to bolt the lap belt on to whatever seats you put in. In my experience, I haven’t seen a seat that has a spot to bolt on the lap belt holder. Just do some research. There is an article in teg tips about putting RSX seats in a DA. It might offer some help to you.
As far as rear seats go, I don’t think anything is interchangable because they all leave a gap on the sides. Most rear seats are smaller than the DA’s. But I have never messed around with rear seats so I could be dead wrong.
all honda seats are interchangeable. i know from first hand i had s2k seats and ep seats in a couple of DAs and i just put BB6 seats in my girls DA bc she thought they were cute. but all you have to do is change the rails brackets and the Pans. with the s2k seats you have to do some welding tho, the support bracket thing on the pan needs to be cut off and re welded on the da pan. but egs and DC seats are quick and easy to change over. as to the rear seats they will work but its a tight squeeze
I had all those seat in my car before…
94+ integra seats- requires you swap seat pans and drill new holes for the da rail to line up…
the seats fit almost to stock height
92+ del sol seat- same as the 94+integra but you would want to use the del sol seat pan…
These sit really low and low really nice
Ep3 seat-requires you cutting off the stock ep3 rails and stock DA rails and welding it together…
these sit high and hugs you good
S2k seat- requires cutting both the sliders and rails off, and grinding off the stock da seat mounting points and welding it all back together…
These look and feel the best in the Da, and these sit really really low…
I had the rear JDM ITR seats the bottom fit ok the side were lil smaller, the tops is a diff story… If you want to put these in your car you can never put your stock seats back in, you need to drill out your stock mounting point and weld in the DC mounting points
